Diesel_brad
Dunce
the BIGFOOT trucks had power rear windows like these. They leaked like a siv and rotted the cabs out. And the motors crapped out alot
I have always wondered about a bronco rear window if it could be adapted. I haven't looked real close because I don't own a bronco.
Here's a post of a guy installing one in a 97.
http://www.olderfseries.net/forum/viewtopic.php?f=2&t=6526&hilit=power+window
He said the the motor for it is missing....does that answer your question?
You need to go back and reread starting with StumpJumpers thread,..
I have a Power Slider and looking at the install thread that Russ posted it looks like the exact same motor and retractable tape and gear that is on mine, I would bet the motors are interchangeable. I can get a pic of it tomorrow if you would like.
I never have my windows open with a gooseneck! They are so loud.I could see it coming in handy during the summer when I am fishing w/ the family. Or if a person had a gooseneck hitch. I used to have one and my window was tinted plus being a crew cab you really had to crank your neck around to try and see it.
Does it work? Mind posting a pic of the switch mechanism and motor?
Thanks,
Carl
Mine works, but i do not have it hooked up to the rocker switch. I will need to hook it up once i can find a new seal for the window, as mine is leaking. Might be a day, were just getting back from the hospital and i'm gonna make sure my wife and little boy get comfy, and then i'll be sure to snap a pic for ya. The motor is attached at the base of the cab in the back. Then two wires are ran under the carpet to the fuse panel cover where a momentary on/off/on Rocker switch was installed. Pretty simple setup. Not sure where its supposed to get its supplied power though.
i still dont know why anyone would want one other than to say"i have a power rear window".......... O by the way rain water comes running in it and the wind noise is deffening. But it looks cool. But thats JMHO
