Possible Dana 60 and ZF 5 Speed ??
Worstenemy453
King George, Va
Im doing the D60 for my 4" lift, the 9' plow that im trying to buy, the custom bumper im having made and the turning radius.
I wasnt looking for duallies, i was looking for any F350. I searched F350.
FORDF250HDXLT
Maine & Oklahoma
sounds like perfect reasons to me.
can you shed more light on turning radius?
does the D60 provide a tighter turn than a D50?
gonecrazyi
florida
My dana 50 rode horribly. The 60 rides far better and the truck feels more stable on the road. Now tha I put the 4 in lift springs on the front it rides and handles far here're than the stock f350 springs.
MA, cape cod
also, the fact that the steering toe changes as the suspension cycles on a TTB truck causes bumpsteer. This gets MUCH more noticable when you run larger tires or have sagging front springs. I have to deal with TTB on my bronco, and honestly I hate it.....and dont even try to wheel with it...the d44/d50 front ends have very weak wheel joints and simply dosent want to flex. However, I do agree if you keep everything tight and just use it for a road truck/light off road there is no reason to change ir.
Diesel_brad
Dunce
gilbert pa
You can use dually front D60s. You will just need to remove the dually adapter on the 92-97 (ball joint ones), or swap hubs with your D50 for a 85.5-91(king pin ones)
Goofyexponent
Mentally Unstable..
Halifax / Nova Scotia
...and then sell me those dually hubs so I can FINALLY turn my truck into a dually. I have EVERY piece except for them front adapters!!!!
crashnzuk
West Sacramento CA
How can i use a dually axle and have 4x4 ?
He is talking a front 60 from a dually will have different hubs or adapters to accomodate the dually wheels. If you don't want to make your truck a dually, you will need to swap to single wheel hubs or remove the adapters depending on what year axle.
Travis..
Worstenemy453
King George, Va
Travis..
I know, but im talking about the Dana 60 in a 2wd possibly not being able to be used as a 4x4 axle because of no driveshaft etc. How can i use a 2wd dana as a 4x4 axle ?
MUDKICKR
NITRO WV 25143
im going to try and say this without being an ass, there is no dana 2wd frt axle.
there are several names for the frt end on a ford trk
TTB twin traction beam = 4wd IFS dana 44/ dana 44hd/ dana 50
TIB twin I-beam = 2wd IFS
MONOBEAM = 2wd superduty solid 1 beam axle
SOLID FRT AXLE = 4wd solid frt axle dana 44(pre 80 trucks)/ dana 60
i hope this helps you.
Worstenemy453
King George, Va
So a dually with a dana 60 can be used as a 4x4 axle or does that mean that no 2wd truck will have a dana 60.
Im sorry but i dont know **** about axles and all.
MUDKICKR
NITRO WV 25143
ssssshhhhhhhhhh dont tell my MUDKICKR that, i have 37s on it and it rides like its on rails, i have also replaced everything in the frt end, and went poly bushings in the shackles and leaf springs. i also cruise on the highway at around 70/80 and if you have ever been on a WV interstate you know how fun that can be.
Worstenemy453
King George, Va
I know right now with TTB and smaller than stock tires in 4x4 that if i turn to the left, my right side front tire will bind up. Havnt had a chance to look at it but i dont like that either = (
