Worstenemy453
a dana 60 is a 4wd axle there are no 2wd versions of it is what he was trying to say.
Okie dokie. All i needed to know.
So a dually with a dana 60 can be used as a 4x4 axle or does that mean that no 2wd truck will have a dana 60.
Im sorry but i dont know **** about axles and all.
Two wheel drive trucks only have a rear differential, the fronts are just steering and suspension. 4x4 trucks have a front differential as well which I presume is what you're after. UNLESS you are looking for a REAR axle, in which case any 2wd rear axle will work regardless of 4x4 or 4x2. If you want a FRONT dana 60 (which it sounds like you do), you will need an 86-up F350 4x4 to source a front axle from.
Travis..
...and then sell me those dually hubs so I can FINALLY turn my truck into a dually. I have EVERY piece except for them front adapters!!!!
