Poorman's intake hat
plywood
Recovered N/A
Portland Oregon
:DSaw this at the junkyard the other day so I grabbed it. I've got an 093 turbo with a snail, so no big deal to me if it would work or not, I just had to have it. I think it cost me about 8-10 bucks.
It was on a Grand Cherokee 5.2l I believe.
It fits the intake of the IDI and has a 3" hose connection.
It curves down though so I'm pretty sure a carb riser would be required.
I haven't figured out yet if I can use the carb riser and still have clearance against my turbo but it might be an option for a cheap intake hat for old Banks turbo setups.
Of course Russ's aluminum hat must have much more flow.:dunno but for the price I'll hang it on the garage wall if nothing else.
Clayton
Ky
I wonder if it would blow apart under boost?
plywood
Recovered N/A
Portland Oregon
I think it'll hold up to 10-15 psi just fine. Seems pretty solid.
Summit probably has the Airraid ones that would have better flow but they are $200 plus for that kit.
I thought about calling Airrraid and telling them I have the kit for the Dodge 5.2l and I need another intake hat and see if they'll sell one alone and for how much.
Hyde
N GO SEEK
Idaho
Not sure how the plastic would hold up, Spectre sells some nice ones in the 100 dollar range. That said I just ordered one from Russ :D
plywood
Recovered N/A
Portland Oregon
I don't even know what Russ charges, but aluminum would be better no doubt. No place to tap for a boost gauge in plastic and this is just intake spec, not sure how it would do under 300-400 degree boost temps.
