Pacific
Gravel Rat
My fuel mileage has dropped to the low 9s to 10 mpg and with the price of fuel at .93 cents a litre this is depressing. Good thing I'am back to working for one of the contractors their shop is only 10 mins away from the house.
My question is does winter fuel knock back the mpg or is it probably from the idling time that is required in the morns lately because of the cold weather and the truck is a frozen brick.
My truck is pumping out the eye watering exhaust smoke too and when I start it up in the morn she really belches the blue.
How bad should the truck smoke if I have weepy valve guides ?
The fuel mileage is the depressing part its creeping down to what a 460 gasser gets and right now the price of gas is cheaper
Do you guys think its my IP pump and injectors getting worse and its causing the bad mileage or its winter fuel. If its the pump and injectors I will suffer with the bad mpg because its well over 1000 dollars to replace pump,injectors and return lines.
