Please help is this normal?
carrasco4712
US
7.3
Sounds like I have something bouncing around in my timing gear case
I had to send the video link to YouTube, for some reason this app isn't letting me upload it.
Sent from my E6830 using Tapatalk
Macrobb
North Idaho
Sounds like gear whine to me - Is it getting enough oil? Oil should basically splash it's way up from the lower gears; that's the only way that gear gets lubricated.
One other thing to try - the top two bolts on the water pump - back them out by 2 turns, fire it up and see if it still does it.
carrasco4712
US
I'll try that in the morning thanks
rhkcommander
Oregon
That's normal?? I'll have to double check mine but I don't recall that hoise
rustygold
conway Arkansas
Mines the same it's normal there is no good oil flow on the top gear.
Sent from my SAMSUNG-SM-G870A using Tapatalk
carrasco4712
US
Thanks everyone. I am satisfied that all is good for this subject.
blakken
sweden
so if i have a injector that is not funktion normaly...can this sound get brighter?
Skickat från min iPad med Tapatalk
a bad injector not only does sound but will also have a visual (white smoke) and physical (engine shake) from imprecise firing.
dented73
