m67tang
What are the Laws regarding picking up waste oil from auto shops? Do I need some type of recycler license?
I don't know about your state but I'm pretty sure CA has rules about the quantity you are hauling before they require a hazmat endorsement. I'm surprised they let you skate on the 80 gallons.
All good Info... Thanks this will help me a lot.
So, what about the centrifuge vs. Conventional Filter for cleaning it to use?
I have no filtration method right now, but if I did I have some small oil sources to start with. right now its hard to justify the upfront cost of centrifuge, but its not worth tearing up my vehicle to save a few bucks to start out with the cheaper conventional filter setup I saw, like the small one at Black Diesel- oiltofuel.com.
I only have a limited start up supply so I dont want to start by spending big $$ just to see if I can develop a real good steady supply for all my needs. Is there a safe way to start small & cheap with out damaging my car & truck, then grow into burning WMO as my supply gets bigger?
if you're hauling more than 275gallons of used motor oil, you fall under DOT rules for all 50 states.
stay under that and you're good. keep it out of sight and you're even better
be smart. have a large sack of asorbent in the truck with broom, shovel and bucket.
if you look and act prepared to handle whatever mess you make, they tend to let you go without playing 20 questions.
Right now I find oil in limited quantities 15-50 gallons at a time. because I dont have any filtration I have not persued a steady supply. I hate that I am passing this up, but if my supplies never improved it would be a waste to spend $1000+ for a centrifuge system.
Fire Department (I was told by hotel staff that they brought out the fire engine)
Where did you find the 275 gallon rule? I've been looking all morning and I can't find any hard facts. The DOT site specifically said that if you're private and non-commercial, you're exempt from their regulations. At the same time, I saw another reference on their site to private motor vehicles? There's tons of info all over the net but I haven't found anything definitive yet.
