i also found out something interesting today....
seems the auto pedal assembly uses the same casting as the manual one. so you could pull the pedals and shafts out of the brackets and swap them if you have a broken casting.
same ford part number...the revision numbers were slightly different but after close scrutiny they are not significantly different...maybe a couple of overflow casting bosses are a there but fit and function they are the same.
