OK Mike I'm gonna tell ya my problem. I've been working on this for so long I don't even know when it started, but I'm gonna try and give you the readers digest version.
One day out of the blue upon starting my truck I get a CEL. It reads out as:
P-1395 & P-1396. Glow Plug Monitoring Fault Bank #1 & #2. With a digital ohm meter I had two (2) dead GP's one on each bank, both against the fire wall.
I replace all eight (8) GP's, CEL continues, Find burned terminal in one of the UVC gaskets, changed both gaskets and all UVC harnesses. Check the top of engine plugs velly, velly carefully. Look great. Get same CEL. Change GPR, some CEL. Double check all UVC gaskets for continuity, Good, Check all points for correct voltage, all good. End result, CEL. I have checked all the fuses, not just by sight but for continuity. Check good.
After my truck sets out all night, temps around 38-42* I will start the truck (right up) 30 seconds running I get the CEL. turn off truck, clear the CEL and for the rest of the day no matter I many start ups and stops I make....
No CEL...........
But I can drive home and park it and immediately check for codes and there they are but all day long (I assume, hate it when I do that) they just lay dormant and don't trigger another CEL.
None of this seems to affect the operation of the truck, it runs good and strong.
The long version of this is that I have had the VC's off three (3) times. I'm really getting quite good and fast at pulling those puppies.
I have checked, checked and checked again and I can't find what the hell is tripping those codes.
I have cleaned terminals, checked continuity of all the wiring that I can and nothing seems to help. Where it the PSD God when you need him?
I'm at wits end unless it's in the PCM.
Thanks for reading my ramble.
Rog
