P 7100 Pump what to buy ???
mudnyeri
robbins nc
Lookin at the dragonfly pump from Industrial Inj. anyone runnin one ?? any suggestions on others??:dunno
kas83
Plover, WI
What is the intended use of the truck? Year, transmission? You looking for more power, or as a replacement for a worn pump? What other mods does the motor/truck have?
mudnyeri
robbins nc
97 3500 4x4 stock now . pump is bad so the price was close on the rebuild here. gonna add intake ,and exhaust, mostly used for towing.
kas83
Plover, WI
I'd go with a reman'd stocker, or see if II will detune a DragonFly for you. They are heavy flowing pumps compared to stock, and will easily overwhelm an otherwise stock fuel system, as well as run warm.
IMO, a well balanced 215hp pump will suit most anyones needs up to around 400 rwhp, with stock 215 hp injectors being used as well.
dmaxexpress
12v cummins
ravenna,oh
ya your egts will sky rocket make sure u have gauges and keep a eye on that. i put 4k springs n mine 0plate and lasor cut dvs and it runs awsome.
twofazed
Ontario Canada
I have a pump that is at 700.000km stock never rebuilt. and was through a fire! still seems functional, just doing a rebuild and looking to rebuild, anyone know who does it in central ontario canada.... or price generally on a rebuild versus new?
Iroc12valve
niagara, ontario
go to taylor diesel in hamilton its about 1700 to rebuild a pump but you know its done right, plus he is a cummins parts dealer
twofazed
Ontario Canada
Alright thanks. That doesn't seem too steep. I want to crank it up a bit though. I'm sure that would only add to the cost.
Faust
