Overheating issues while plow is attached
maximus88
Sussex,WI
My truck usually runs pretty cool to average. Never had an issue all summer with over heating.
Anybody else have problems when the plow is attached? No problems whatsoever without plow attached. How close to the ground do you have the blade when driving. Is my Fan clutch bad? It is pretty fricken cold here 18 F.
Jbevs
IDI Newb
IL
The plow is blocking adequate air flow to the rad. I don't remember how high or low you are supposed to have it for driving.
oldmisterbill
Grumpy Old Man
Wagoner Oklahoma
I agree on the fan clutch. But I would advise not to run with the plow any higher that necessary-the higher the plow the more the air is blocked from the radiator.I had plows for over 30 (usually 3 to 5 some driven by hired help--- HELP!!!!) years and cooling was always a concern. I cooked a C6 once when snow filled the grill blocking my trans oil cooler only took a 300ft slow hard push,and it was done.
Diesel_brad
Dunce
gilbert pa
If I want to lock it do I just weld it, or is there a way to bolt it?
YOU DO NOT WANT A FULL TIME FAN.
I do not fully agree with the others. I think it is the plow alone causing your problems, not the fan clutch. A friend of mine tows year round w a small block and a 25' gooseneck trailer(grossing 18k+) and it NEVER comes off of cold. As soon as he hooks the plow on, it gets hot. Lower your plow as low as possible, with out scraping the ground. that will fix your over heating issue
LCAM-01XA
my very own hell
Can't welt it, it's a steel shaft that goes into an aluminum hub. As for locking it, several members here have some pretty nifty setups, do a search and you'll find some with pictures and such.
trackspeeder
Stone crusher.
North Branford. CT
Try running the plow lower to the ground. If you leave the pow up to high it will restrict the air flow. When I wanted my plow rig to heat up quickly, I would leave the plow at max height.:D When it was warm enough, I would run the plow about 2" off the ground.:Thumbs Up
maximus88
Sussex,WI
My buddy told me to run with the plow at an angle. I will try that and also try running her really close to the ground.
94turboidi
Ne So. Dakota
Its hard to believe that at -18 that the plow is going to be a problem. I don't know anything about the plows but I would think you could just about block the radiator clear off at those temps and not overheat. I would look strongly at the rest of the cooling system before I decided it was the plow height.
maximus88
Sussex,WI
It was 18F not -18F. I would really be worried if it happened at -18.
FORDF250HDXLT
Maine & Oklahoma
im with Brad here 100%.;Sweet
FORDF250HDXLT
Maine & Oklahoma
you must have bypassed the radiator trans cooler/warmer and ran only the devoted air cooler?
Bo17
