89dieselbko
If not this weekend, then starting next wednesday the 7.3 is coming out of the bronco for a complete (ish) tear down. Going to reseal everything for sure, oil cooler for sure, still have to order injectors, and a pump (found a local ish shop that will take my pump, rebuild it, reinstall *free* time it *free* and garuntee it for 50k miles, no labor/parts out of pocket) so i might give that a try and its a bit cheaper then the moose (total for pull, rebuild, put back, timing, +warrenty, $420) i dont have to worry about timing, even more so with the timing rental program down as i last read that would be a nightmare, and of course, gives me a couple hundred extra to work on a turbo kit deal.
I want to do a compression test on it, hoping i can *borrow* one from a buddy that has a few idi's as hay haulers
I dont want to tear THAT MUCH down if i dont have too, rather not re-ring it and have to pull the crank out, but hey, who knows.
The 7.3 weighs, according to a few sources online, 920 dry, so when i pull it, figure 1000 (flywheel is coming off before i let tension off the cherry picker, that may or may not be in the weights i was reading) so im stuck in a conundrum... I have a 750lbs engine stand (i know to small), was looking to upgrade for safetys sake. Would a 1000lbs engine stand be good enough? Anyone had a 7.3 on a 1000lbs stand for an extended period of time? Im thinking with winter coming it might be down until march or so... 6 months (will be at least partially disassembled most of that time)... Any opinions on that stand? I was looking locally at some 1250lbs stands... but for that extra 250lbs the price jumps $100 or more (cutting into my budget)
Is it worth the extra money for the 1250, or would the 1000 be sufficient for my needs? i dont plan on tearing out crank/pistons so the stand wont be taking a beating, just sitting in a corner covered up (i hope).
Second question... what do you guys use to coat the inside of your engines when tore down to prevent flash rust and all that fun stuff... i used WD40 when i built my 331 stroker and it worked well... but is there something better perhaps?
As always thanks guys!
