just the carrier spirals, helps sling the oil.lol
That's what mine had. So it's somewhat "normal"??
Then it must've been a previous scar. I'll ask the PO (boss man) if he had any work done to it before.
It's a 94 so it doesn't have the crush sleeve crap.
The u-joint has a little play, but the pinion itself had zero play.
What would the best way be to "flush" the old fluid?
You won't see the crush sleeve until you remove pinion from the housing!I'll get some pics up later, but it's definitely not a crush sleeve pinion. It's just a seal.
Maybe it was swapped from a different year.![]()
Way I did it was put RTV on yoke splines only, then as you push yoke on shaft the RTV don't get jammed into the bearing. After yoke is all the way in (hold pinion head in or it will try to slide out on you) smear some more RTV on shaft splines sticking out of the yoke. Apply loctite to nut ONLY, cause if you put some on the shaft it will be forced into the RTV as you tighten nut, and RTV and loctite don't mix well.Then disassemble install NEW seal and then install some RTV on the pinion splines and yoke splines, then a NEW lock nut with RED Loctite.
What Riotwarrior said, AFAIK all 10.25 Sterlings have the crush sleeve. If it has a solid spacer and some shims, then someone converted it to that setup. Which is good for you.I'll get some pics up later, but it's definitely not a crush sleeve pinion. It's just a seal.
Good points, I'll have to take pictures when I do this, I'm not slathering the stuff on and explaining is not worth effort. Pics say it all and I completely agree with your technique!Way I did it was put RTV on yoke splines only, then as you push yoke on shaft the RTV don't get jammed into the bearing. After yoke is all the way in (hold pinion head in or it will try to slide out on you) smear some more RTV on shaft splines sticking out of the yoke. Apply loctite to nut ONLY, cause if you put some on the shaft it will be forced into the RTV as you tighten nut, and RTV and loctite don't mix well.
