one fuel tank
Vegas-Misfit
Seaside CA
Im trying to go to one fuel tank of 33 gallons or larger... i want to get rid of the selector switch so that is one less thing on the truck to fail. i was curious if someone could point me in the right direction... whether it be a tank under the bed in place of the spare tire or in the bed... thanks in advance for the help guys
There is a Bronco tank that fits in the rear tank position but you loose the spare tire cause its so large. Transfer Flow makes a good size rear tank too but they are really expensive. Others will chime in with more info on a 30 plus gallon tank.
Vegas-Misfit
Seaside CA
transfer flow quit making there tank for the slant nose... and the bronco mod looked appealing but curious which tank i would need to make it work
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
Actually, as far as I can tell, Transfer Flow doesn't make tanks for ANY '80-'97 Ford anymore...the oldest Ford truck they make tanks for is the '99 SuperDuty. You can still buy an in-bed tank, but no more tanks in the OEM locations. The website says they still make fillnecks for '87+ trucks, but I don't see the fillnecks listed for sale anywhere...
"if" you're lucky enough to find a wrecking yard that processes retired towtrucks, many were fitted with extended cap side tanks. the wheellift assy took over where the rear tank resided. i do have a 45 gal rear tank from transfer flow from a barter deal years ago. only thing that kept me from using the tank is the weight added behind the rear axle. in-bed tanks must be used with caution due to problems with fuel return. noticed the oem tanks are below the fuel injector return lines?
Thats a great point made about in bed tanks being higher than the oem tanks for the gravity flow back to a tank. I guess enough pressure would be made in the return line to push fuel into the bed mounted tanks.. IDK for sure on that. Just a wag..
Bronco tank can work, I did fit mine, however it was NOT installed and nor did I take pics. I'd rather have a 45 gallon aftermarket so I can take some .090 or .120 tubing and say....3" dia and push a tube into and through the tank to make a PTO shaft opening or even a hyd line opening ...but PTO likely for winch!
Just sayin...
Efn bronco tank was too damn rusted out :(
Dsl_Dog_Treat
Decatur,MI
I did the Bronco tank mod on Darrins truck a couple of years back and it was a tight squeeze but it did fit in there like a glove. Just some modding needed to be done to the sending unit due to the extended depth.
Vegas-Misfit
Seaside CA
i am not comfortable modding something that important... i would rather just buy a new sending unit that would fiot it... if that exists
NO_SPRK
User & Abuser
Santa Rosa, Ca
I found pics of both transfer flow tanks on a 96.. when I get home ill post them. You can read the part numbers
