oil use going up
Black dawg
sw mt
over the last year oil consumption has gone from maybe a quart in 3k to recently a quart in 1k or less. blowby seems to be the same as before, and never smell any oil burning or oil smoke ever. turbo seems pretty dang loose, never was very tight even brand new, and I am suspicious of it. Whats the easiest way to prove/disprove the turbo leaking?
bigoilburner19
circleville ohio
to me id replace to whole thing if it was my truck or just live with it until you use more oil, but then if it was loose to begin with then i think you should replace or rebuild i dont know much about turbos but can you rebuild them????
dyoung14
Is getting worn out
spencer,tn
I wish my engine only went threw a quart every 1K, between my leaks and it burning it i put about a quart every 1-2 weeks, maybe 300 miles:eek:
93f250idi
strokin
cadiz ky
wow lots of oil that you could be burning as fuel lol. btw what kind of fuel milage u get with the turbo?
Diesel JD
Gainesville, FL
First of all bigoilburner, yes turbos can definitely be rebuilt. Usually if they aren't too bad that means bearings and seals and 1-2 hrs of your or a shop's labor. If there'sa lot of abrasive damage then a new compressor wheel is needed and if forbidden guests have been getting to know each other (IE compressor wheel hitting housing etc) more extensive repair may be required. @93 1 quart per 300 miles really isn't terrible on a 6.9 with a few hundred thousand miles on it. A 6.9 usually burned some oil even when they were newer. An exception could be a really tight rebuild or an engine that was broken in properly(IE not babied too much so the rings didn't have to work against an oil glaze built up on the cylinder walls) a 6.9 also had non positive valve stem seals. @Black Dawg, I might also suspect the turbo seals in your case, usually it's the rings, but if blowby and smoke seem the same and your turbo is a bit loose, well you might even want to pull that thing off and thrw a turbo kit at it. Probably consideringa ll the wrenching and custom work you've done on IDIs a turbo overhaul is withing your level of expertise provided it only needs the bearings and seals. It would probably be pretty cheap compared to any other option you might have other than doing nothing and let it develop, which also might not be cheap in the long run.
f-two-fiddy
Duluth, Mn.
Check Your intake pipes for oil.
dyoung14
Is getting worn out
spencer,tn
I have seen 23 when i drive easy and by easy i mean never getting over 50, and shifting at 1500 rpm in every gear,
bigoilburner19
circleville ohio
thanks for clearin that up for me but i never knew a 6.9 used so much oil well it is the nature of the beast
FordGuy100
Silverton, OR
Try some auto rx. Seems like snake oil but my truck went from a quart every 500 to about a quart every 1500miles or so.
