boxathey
Hello, i have a 1993 f350 7.3 idi with a factory turbo, I installed new qauges and my oil pressure seems low. I tied in at the top of my turbo with a T right with the factory oil pressure sensor. at idle my truck is at 19-20 psi. running down the road it only jumps up to 22-24 psi. it seems crazy low to me. is the factory sensor spot a bad location for accurate numbers, or do i have bigger problems?
i also would like to know where you guys recomend installing the water temperature gauge probe on my engine. the gauge states that it needs flow to properly read. i was thinking mounting it on the very top of the water pump. there is an extra port on top. or should i disconnect the factory sensor and use that hole. i dont think i can use a tee cause it wont have proper flow
thanks for help
Joe
thanks for help
Joe
