Noisey Diesel 6.9
Noiseydiesel
Hillsboro, Ore
Greetings.
I originally posted this in the newby welcome forum.
My first diesel so far is an '87 F250 with the 6.9. It came home pretty much a non runner and I got educated fairly quickly. It was running when I showed to buy it (never a good sign) and after a short test drive and looking at a few things, it was shut off, I let the previous owner keep the used batteries for another truck and had it towed home.
Sloppy steering column was the largest reason for towing it, and if towing it, didn't need batteries or used ones to start this project.
Engine wise, it got a new controller and Motorcraft, NOT Autolite, injectors. The prior owner had a toggle switch in the dash to energize the injectors.
I rewired it so the toggle switch can now be used to energize the controller when needed for a cold start. The rest of the day, the switch is off and the controller is not needed. This set up is also handy in case the ign switch needs to be turned on and the glow plugs will not be cycled.
Leaving the controller set up as original allows for normal operation when the truck is used by anyone else. Usually I run the glow plugs for 8 to 10 seconds before cranking the engine, then turn off the toggle switch and don't use the controller& glow plugs for the remainder of the day.
One slight oddity is I fired it up a few days ago, not a daily driver truck, and after it ran a short few minutes, the engine got quieter. What? Yep. Noise output seemed to drop no less than 30% and it seemed to smooth out just a wee bit. Then about 7 seconds later, it went back to being noisey. No smoke from this engine and I never gave the pump or injectors a thought until this happened. I suspect I need to go out and warm it up, then crack fuel lines and see if I can hear an RPM drop. The wife and I took it on a road trip with a 1990's vintage slide in camper the mileage went from about 15 MPG down to about 8 at some times. I am used to gas engines and can feel a misfire easily enough. This diesel routine is a new one and I am still learning a bit.
Other than that, I have replaced the fuel pump, vacuum pump, water pump, fan clutch, coolant.
So what is your opinion? No smoke and varying mileage with excess noise?
Possible injectors? At $35/40 bucks each from Rockauto, I hesitate a bit to drop $340 into this as a SWAG.
Thank you for your time.
Bruce
DrCharles
West Plains, MO
The noise may be your cold advance changing... check the power to the advance solenoid and make sure it's not going on and off. When our IDI's have the extra advance, they sound quite a bit harsher with more diesel "clatter". Once the coolant is over 112F(?) the temp switch is supposed to open and disable the advance. Instant "normal" diesel sound :)
I think you mean "glow plugs" here ;)
Oh, and welcome to the forum!
hesutton
The Anti-Anderson
Bowling Green, KY
This was what I was going to type as well. Just normal when the engine is cold. If all the components are working correctly, there is a solenoid to bump the throttle lever to increase the idle RPM and also one to advance the timing until it is warm. Once it is warm, those shut off and it returns idle and timing to normal.
Any idea how many miles are on the injectors and injection pump? If they need replacing, I'd likely not get a set from Rockauto or a box store. I've have excellent performance with injectors and IP's from Mel (Agnem is his handle here) at Conestoga Diesel.
Heath
lewisstevey7
