Dieselmaster
Diesel addict
Well a while back I gutted my EBPValve..
The thread about it is around here somewhere....
Anyways, I get back home from Vegas this weekend and go to drive my truck and there seems to be a new noise from the motor area...
It sounds or should I say "IS" the turbo whistling... but much more noticeable than before... It wasn't doing this after I did the EBPV... Today is seems to be worse and somewhat of a flutter.
Now I mentioned the EBPV but I was also having a problem with the Intercooler boots... They started popping off anytime I hit over 25psi... so I replaced those the weekend before last... actually only the two upper ones...
I am going to check all the bolts for the EBPV and see if I have a leak in one of my lower intercooler boots.... but can you guys think of anything else I should check that might be causing me the problem...??
BTW the noise seems to be coming from the airr filter area more than the other side of the engine area... and will only make the noise under load...
one last thing... when I gutted the EBPV, they only had a Brass/copper looking plug that would fit... so that is what I got... do you think it is up to the heat that the turbo can get to.??
