No WTS light but still starts.
Sycostang67
Scooty Puff Junior
Kuna, ID
Aside from my unbalanced flywheel issues, I have noticed something else. I put in a new glow plug controller as the original one was working intermittently. I also have an LED wired to the controller as well. My LED comes on but the WTS light does not. I wait for the LED to shut off and the truck starts so I know the controller is working, but why not the WTS light? The WTS light was working before I replaced the controller. I know it's not a huge deal, but I like everything to work as it should.
GreenDiesel
Austin, Texas
that plug can be a bit deceptive, I didn't have mine plugged in all the way after did my return lines, and the WTS light didnt come on. Push it all the way in until the little plastic boot inside compresses and you hear/feel a click
Midwest_Mudder
Kennard, NE
check the bulbs... seriously. ask me why i say that, i went through everything, actually check em twice. i checked my bulb, worked fine, put it back in, no light. checked EVERYTHING else, checked the bulb again, wasnt working. so now i have a set of LongLife bulbs in there...
Sycostang67
Scooty Puff Junior
Kuna, ID
I did plug it in, but there is a good chance I didn't seat it all the way. Guess I will check that first.
Sycostang67
Scooty Puff Junior
Kuna, ID
I managed to check that wire while I was replacing my flywheel..again. As soon as I touched it the plug separated. I made sure to hear it click this time and my light is working again. Thanks guys.
MOWOG
Gearhead
Bothell Washington
I would consider moving the wires over the top of the fuel return line between the last two injectors... less chance of the insulation melting. I believe that's the way it came from the factory. At least mine did.
