Diesel_brad
Dunce
It all started 2 days ago. Went to start truck and she turned over real slow. And wouldnt start. So i put the charger on it for 2 hours on 2 amp and she fired right up. Had the proper volts and had no draw. Was only charging at 12.5 at idle but i figured it would charge more off idle.
Today. I take her to work, work till noon , go to moms, then hit advanced on the way home. went to leave. Truck cranked REAL slow again. Had to get jumped. Then she fired right up. Went home, swapped the batteries out of a running parts tuck i had. She fired right up w the new used batteries. Went to advanced to get the old 2 batteries load tested. They checked out fine, just needed some charge. Went to leaved advanced . Cranking REAL slow again, needed jump to get her started.
Came home, pulled the starter. Put in a 88 7.3 starter i had on the shelf. Little smaller and lil different but bolted in. Now it cranks even slower!! I'm at a loss guy. Help me out could the used starter i put in be as bad as my old one? O... the old started dropped battery voltage down to 3.5 v while cranking. I didnt check the new used one.
