chrisschreurs@
Vitamin-C
Ok. So I've been working on this truck a while now. 86 F350 CC DRW 6.9idi. I've replaced the injector caps and orings and lines. Rebuilt the oil cooler(that was fun). New front fuel tank(both were rusted, however, I've only replaced the front tank for now. I got it running and drove it around, Realized my front brakes weren't working. Replaced the calipers and master cylinder. Drove around some more and it was running great. Later that day, it started, idled rough, and died. I can fill the fuel filter and get it to start. I've put a new lift pump on as well.
My guess is that there is something wrong between the lift pump and the fuel tank. I can disconnect the line from the back of the fuel filter housing that comes up from the lift pump and fill it with WD40 and it will "squirt" it back out, but hardly anything after that if at all.
Any suggestions?
Any suggestions?
