Hey folks,
I recently picked up my first diesel truck. 99 dually. The guy I bought it from told me it has a 100 hp chip in it, is there any way to verify this? I do see that it has a Van Aaken pump controller box. From what I have seen that is not the "chip" correct? It remaps the fuel? Is there really a chip in it, or do you just use a programmer?
Also, being new to diesel, anything I should look out for? I have been learning as much as I can from this site. My vp44 and lift pump are new (prev. owner said lift pump went out and took out vp44) but I don't have a fuel pressure gauge...I will be getting one of those.
My last big question, how much boost shout I be making? From my reading, I have learned boost isn't just determined by the turbo. So, I was told that it has bigger injectors, the turbo had been sent out and redone with bigger bearings, and it has a 100hp chip in it, looks like exhaust is mostly stock but it is a straight pipe. I can only get the gauge to hit 19. I thought i read that the ecm allows 23 or so. Now this is only mashing the gas in town, haven't towed with it yet, but it will pop to 18 in about half a second and hold there till I let go. Do I need a "boost fooler", where do I look to see if I already have one?
I know I sound as dumb as a box of rocks, but diesels aren't my thing. I think I could be, my ride is kind of a hot rod...let the guys I work with that have diesels drive it and they're jealus. Ask me something about my big block nova I drag race and I can talk shop.
Oh, did I mention I only gave $4,000 for it!!!
