new truck is throwing some curves
91idi
Fiberglass *****
X
My 88 diesel seams to be a good one so far. LOL
Transfer case shifter loose- found loose bolts and fixed it
Breaks were hard but worked-replaced the thing on the side of the ip
Now i need to know how to set the "thing" on the ip that controls the trans. Its a C-6.
Also the fuel gauges stay at empty till its empty then it shows 1/4 tank.
Finally what else should I look over? I Already ditched the soup bowl and the cdr valve
91idi
Fiberglass *****
X
Not it. Its a C-6 not the eod4
91idi
Fiberglass *****
X
I have one i need to know how to set it the correct way. Thanks for the correct name
Brianedwardss
Oregon City, OR
Loosen the two screws, tilting it towards the front of the truck makes it shift harder, pulling it back makes it shift soft. Both of my C6's are about 8 millimeters forward of being all the way back. It's easy to get to, and easy to fine tune what you prefer for shifting characteristics. More towing = further forward. To start, I'd pull it as far back as possible, then tip it forward a touch and take it for a drive.
91idi
Fiberglass *****
X
Thats where i set it. I don't like it because it really jerks into gear. I'll set it back a little more. Thank you very much for your help
Brianedwardss
Oregon City, OR
Yep. If it's all the way back and still shift like a mule, it may be bad or you're low on vacuum. But we'll worry about that later :)
BTW, vrv part number before I lose it: FOTZ-7B200-A
