sle2115
NRA LIFE MEMBER
Ok, after getting the filter problem resolved etc. I noticed that my "Engine" light was on. Starting looking and my temperature gauge (in dash factory) that is unhooked and usually reads nothing, is PEGGED! The sensor for this gauge, is removed - I think! I removed the sensor in the timing cover and unhooked the wire and put my sensor for my VDO gauges in there. I believe I was told this was the correct place, anyway, it has worked fine until now (over a year). I still have a sensor located in the front of the cylinder head that I believe was said to be the sensor for the cold idle advance - am I correct in the purpose of these two sensors? Anyway, when I disconnect the sensor in the head, the gauge goes back to "no reading" and the engine light goes off, which makes me beleive this is the gauge sensor. Anyway, the gauge worked fine until I unhooked the timing cover sensor, then it just went to the cold side and has stayed there for a year or more. Now all of the sudden there is a change.
Someone help me out here:
Is the sensor in what I am calling "in the timing cover" the one for the gauge?
Is the sensor in the front of the d-side cylinder head for the cold advance?
Will Jill and Tom get married or will Sally bust up that relationship because of the previous relationship with Jill????
