Next time you get PSD envy, and wish you had a high idle controller accessory, don't envision an expensive Ford factory option with more fancy computer chips than you can wave a static charge at. Instead, read THIS Then go find your truck payment book, and remember that you don't have one.
Even if you don't do any of that, check it out anyway. Ron worked ******* it.
Anyway I got a question though, can you literally set the rpm to anything you want and then "flip the switch" to on and it will hold that rpm or does it hold at the factory normal fast idle speed? Again thanks for the article!!
