LA350
Well it is new to me anyway. After much anticipation, I finally picked it up today from my Bro-in-law. It was his father's and due to his health he can not drive it any longer so my wife and I got to bring it home.
It is a 92 supercab F350 XL Dually w/5 speed xmsn, factory dual tanks, and a 4:10 rear w/ 115k miles on the odometer. I was looking through the glove box and found the window sticker, pretty cool
. It has the camper package, I guess that mean factory hitch. There is a ball for a gooseneck in the bed too.
My BIL just replaced the motor in the windows replaced as well as the serpentine belt as well as the idler pulleys. He said he was driving it and the Serpentine belt vaporized as he was coming off the highway.
I looked the truck over and while not a showroom beauty it has a good chance to clean up pretty good. The driver side rear fender cracked and had some work done to fix it. It stated quick cold and hot
but after a long idle and popping the hood I smelled fuel. I climbed up on the bumper to peer inside and noticed 4 of the injectors were leaking, on was leaking pretty good. Not just wet, but producing some steady drops of fuel.
My FIL didn't drive it much for the past 5 years mainly back and forth to the dump and some short hauls w/ his tractor. So it mainly sat parked. There re some dry rotted vacuum lines my BIL pointed out but he had no idea where they went coming out of the passenger side of the firewall.
I added 2 quarts of oil, filled both tanks, added some 2 cycle, hooked up the trailer that came w/ the truck and headed home 2.5 hours. The truck is basically stock runs great! Sounds even better
Plenty of power, 3rd and 4th really show the muscle and 5th is nice for easy cruising. Never knew the big iron trailer was in tow unless I looked out the rear view.
I have to get used to the shifter though. One really has to push up the rpms to get a smooth shift w/ out losing too much momentum. Also, it has a tendency to want to hop in 1st and reverse.
I am pretty pleased w/ it and damned happy/proud to have it. I would like to open up the exhaust and add a decent air filter to help it breathe. I was thinking a small body lift too...But I need to tend to the issues at hand first and clear up some of the cosmetic details like removing all of the old tint that is crumbling off the windows
give it a nice bath and compound off the old oxidized paint, change the oil, fuel filter, ect.
Any other suggestions for the mighty
F350
Thanks!!
Trey
but after a long idle and popping the hood I smelled fuel. I climbed up on the bumper to peer inside and noticed 4 of the injectors were leaking, on was leaking pretty good. Not just wet, but producing some steady drops of fuel.My FIL didn't drive it much for the past 5 years mainly back and forth to the dump and some short hauls w/ his tractor. So it mainly sat parked. There re some dry rotted vacuum lines my BIL pointed out but he had no idea where they went coming out of the passenger side of the firewall.
Plenty of power, 3rd and 4th really show the muscle and 5th is nice for easy cruising. Never knew the big iron trailer was in tow unless I looked out the rear view.I have to get used to the shifter though. One really has to push up the rpms to get a smooth shift w/ out losing too much momentum. Also, it has a tendency to want to hop in 1st and reverse.
give it a nice bath and compound off the old oxidized paint, change the oil, fuel filter, ect.Any other suggestions for the mighty
F350
Thanks!!
Trey
