Needed: Replacement IP Timing Cover and Oil Filler Tube
mankypro
Learning Slowly...
Boulder County, Colorado
Can't seem to source these anywhere locally. All the diesels in the yards nearby are engine-less.
PM me if you have both items in good repair you'd like to sell.
DeepRoots
Tug Engineer
Douglas, Georgia
if not, I have a junkyard local that always has 10-20 idi equipt trucks handy.
it'll more than likely be 7.3, but I might find a 6.9 version.
lmk if typ4 doesn't have one, I'd be happy to buy ya one.
mankypro
Learning Slowly...
Will the 7.3 version fit my 6.9?
I need to replace it as I discovered that the inside was a little munged when I replaced my IP and the driver's side bolt hole for the filler tube is stripped a bit - this means I need to slather the RTV on to keep it from leaking much oil when changing oil to avoid leaks.
typ4
Newberg,OR
The 7.3 will bolt right on. I have a really nice one. pm me.
k_williams1982
'01 Excursion 4x4
Santa Rosa, CA
I have a timing cover with oil filler from a 6.9 with the "port" for the tach. Just keep us informed on what you want and when you get one.
