Hey guys,
While working on my grandpas truck, the one we rolled, we noticed one rear tired looked a little cockeyed. Well one of the axles must have been bent in the rollover.
I dont know what rearend it is, but its not the DANA full floater like what all my other trucks have. This one has a light rear with no hubs sticking out.
My bro wants to just put a new axle in it. Its the drivers side one.
If you know what rear this is please let me know cus I dont.
Ok I am not sure but it sounds like you have a semi floating axle, of what type be it a Dana like the one in the auction link or a Ford Sterling I am not sure.
Please look here
http://coloradok5.com/axleguide.shtml this will show you the different rear ends and you can clearly see there is a significant difference between the Ford Sterling, or the Dana.
Ford did use both types of semi floaters, more than likely yours as early as it is is a Dana.
Just a though you may want to consider is if the axle is bent, the housing may be bent as well. You would do well to find a good reputable shop and have that checked out thoroughly. If you put a good axle into a bent housing your setting yourself (or who ever drives the truck) up for a axle, bearing or carrier failure due to the stress' involved.
If you can take out both axles along with the carrier, replace carrier caps and can access a very long straight tub that fits through the complete housing, you may indeed be able to see if the housing is bent.
You'll have to ensure that the tube, or bar that you use has no deflection.
Imagine if you will, a specially made donut x2 that fits into the carrier bearing spot held in place by the bearing caps. Now that donut has to be machined perfectly with a hole in the middle of each that the bar stock or tubing just fits into. Pass the tubing into the donuts (already installed in the diff) and once the bar/tube is completely through the entire differential, you should see that the bar/tube is perfectly lined up in the middle of the axle ends of the differential. This method is the surest method as well as simplest one of checking for a bent housing.
The two axles here
http://cgi.ebay.com/ebaymotors/ws/e...Track=true&ssPageName=VIP:Watchlink:middle:us
are both Dana axles, not a Dana and a Sterling as mentioned elsware in this thread.
I do hope this helps
