Need New Serp Belt
dakotajeep
Patrolling
TN/ND
I bought one from *cough* Advance *cough* since they are close but it seems to be too short. Does has anyone replaced theirs that know the part # and where they got it from? I almost lost it when the serp belt didnt fit since they also sold me a tensioner that didnt work!!!! Talk about some wasted trips to Advance.
Thanks
Thad
dakotajeep
Patrolling
TN/ND
did ya go on there website and run the number one the belt.
Yeah, but its shorter than the one thats one there. I understand they should stretch a little but....I had the tensioner all the way over and it still couldnt fit. I put the old one back on and it seems to works fine but I definately want a new one since the old one was routed wrong and is pretty worn.
creighta
Sardinia, OH
I go a new belt w/ when I installed the a/c kit in my truck last spring. It had the same problem. I had a friend hold the tensioner down while I worked the left side partially on, then I cranked the ignition and it jumped into place.
Granted this wasn't a great idea, but it worked and the belt stretched out to feel o.k.
Dirtleg
Cloverdale VA
I put a new belt on in August had the same issue. It came up just a wee bit short. I found that if I put the belt behind the tensioner and then cranked the tensioner over all the way I could then get it over the A/C pulley and then slide it onto the tensioner. It was a pain for sure but went right on once I figured out the right sequence.
Double check your part # as has been mentioned so you're not wasting your time just in case. Good luck.
dakotajeep
Patrolling
TN/ND
Totally redneck..cookoo ..and I love it...Still got all your fingers? :rotflmao
dakotajeep
Patrolling
TN/ND
I think this just might work for me.....
Russ
Idont do injectors
New Brighton PA
I can't find it now but IIRC it's either 112 1/2" or 111 1/2" It's the 1/2" that makes all the differance
IDIJunkie
Milan, IN
I always end up loosening up the alternator bolts about a 1/2 inch and it makes the belt go on so much easier.
Exekiel69
I buy them at napa and they always fit the first time with no hassle, I don't buy any dayco belts at advance anymore, I know it is better to come with the right size but I never need it when I ask for the belts at napa.:dunno
