glad you explained that cause I dont have the time, well explained.
woulda been cheaper to haul it up here
when you talk valve springs, you need to be aware of several things. Install hight and coil bind are verry important in a high lift system. The IDI is not a high lift engine so spring rate is more important. The stock springs are about 85lbs seat pressure closed and the 910 is rated a 92lbs Now the closed pressure can be ajusted by the installed Hight. but you can only shim so far or you risk coil bind. Knowing the range of opperation of your valve train (the valve lift) you can adjust the shims to get the closed pressure you want and the open pressure you need to keep the valves from floating. The spring rate per inch is what changes the open pressure. The comp 910 spring is a good upgrade from stock, You can install them in the IDI without checking anything and they will be fine. The stock install hight is right in the sweet spot on the 910's range. The PSD guys like to shim them to 1.70 when they run over 50 psi boost. The 910 springs can handle .500 lift when installed at 1.85 giving a 92lb closed and 300lbs open at 1.35. The Typ4 cam lift is .392 (from my specs given to me by Russ) so we can shim up the springs to increase pressure closed and still be safe. It is posible to calculate open pressure if you use some math. Its better to use a spring machine to see the rate. I have done some looking and found one other spring that is close to the 910 its the comp 926 its 108lbs at 1.80 and 317lbs at 1.30 the 926 has an OD of 1.475 (The stock spring is 1.40 OD) and a rate of 418lbs per inch. I dont think it is needed because its not a big enuff increase, I was thinkin about using them but have changed my mind I will be using the 910's instead. I will be shimming to about 1.80 and using a j2 cam. Just thought I would put my .02 in
