Need interior info???
SDbernhardt
United States
I'm looking to replace the seats in my 94 crew cab.. front seats are wore slam out and want to dynamat the floors and whatnot when I rip them out. I was wondering what seats from other year trucks can be put in this cab with minimal fabrication?? Thanks in advance.
I don't remember the specifics. Just search. Was talked about a couple months ago.
83ford
ford diesel baby
calico rock.arkansas.us
What seats do you already have?im not sure how people do the mounts but newer super duty seats will work.ive thought about it also so maybe someone here has done it an will chime in
Sent from my Iphone using Tapatalk
i have 96 interior in my 87, was a direct bolt in.
the SD middle seat i have needed to be re-drilled.
this would be the rear seat in a CC
In general, cc and reg cab seats seem to be cross compatible. SC and bronco front I believe are directly cross compatible as far as mounting goes. The shapes of the floor pans are what dictates that. If you can use your seat track (assuming it's good) then options are pretty wide open. There are seat tracks that will let you use the split buckets and bolt to the bench seat locations. They show up on fleabay from time to time and are usually pricy.
tke395
