homelessduck
E4od , and I've just been jumping the starter and IP . Seriously thinking about buying an electric pump .. this is a bit ridiculous .
I just rigged up a temporary setup with an E pump .. It's feeding straight into the filter head . Now , do I still need to crank the engine over to clear the injector lines ? I'm thinking I do, but not sure .. I just tried Cranking it with the IP on and w/o , with the E pump running and the hard lines cracked .. still don't have fuel to the injectors. Should I just keep at it until I see fuel ? It honestly sounds like its just pumping it through the return lines and not through the IP and injector lines ..
Then I have to wait an hour for it to charge lol .
