I still think you need to do some more testing:
1) Do you get fuel out the front of the IP with the hard line there removed?(with epump running)
2) There is a screen filter where you removed the hard line from the IP, its a PITA to get to, is it clogged?
I am just thinking out loud, others here know far more than I do. To me, if you have fuel at the IP inlet and not at your injectors, you problem is in-between, test each step in-between.
If you are thinking about taking off the top cover of the IP, be warned not to disturbe anything in there while you have it off and get it back on exactly the same way, re
ut of control overreving until engine is junk.
