Need E4OD help
trackspeeder
Stone crusher.
North Branford. CT
It's blinking because the TCM has fault codes stored. The TCM can hold codes and not dump into limp mode.
Because its shifting through all gears, the TCM is getting a tach signal. Scan it for codes.
oil_rig_medic
Texas
Checked codes again ast night, 11 & 15. Cleared them again but came right back, truck is still running fine though
FORDF250HDXLT
Maine & Oklahoma
(O) = Key On Engine Off test
(R) = Key On Engine Running test
(M) = Memory code
11 System checks OK -
15 (O) No Keep Alive Memory power to PCM pin 1 or bad PCM (Memory Test Failure)
(M) KAM (pin 1) was interrupted (was battery disconnected ?)
prepowerstroke
tuscarawas county ohio
Which fuse is the TCM fuse? And would it be the same on a 1990 7.3? Bc mine is having the same prob but it's going into limp mode
direwulf23
Botkingburg (NCen), AR
Number 22 in the power distribution box. Is a 20 amp maxi, in the middle row, last one away from the Fender wall
1994 Ford F250 Superduty, 2wd, 7.3L IDI, NA, E4OD
direwulf23
I honestly couldn't say. Did the brick noses have an e4OD. I wouldn't think a C6 would have a TCM
direwulf23
Oh, I stand corrected. Lol
I'm not sure but I know that's how my 94 is set up. I would guess it's similar but that's all it is.
I had a problem with the fuel preheater blowing my TCM fuse, they are stupidly on the same fuse. So, I simply unplugged the preheater
prepowerstroke
Okay bc that sounds like what my 1990 is doing, the tach don't work and trans is in limp mode(won't shift have to shift it manually from low to high lol
direwulf23
Lol, I was thinking slant nose.
My tach wouldn't work and it had no take off, let it was starting in 3rd or something, but reverse worked. Everything just went screwy, basically
truckonfire
