tbiagent69
So my truck has a little over 120k miles on it and I have been consistantly getting less than 10 mpg. I inspected the injector system for leaks and I can see some fuel sweating from the return lines on a couple of injectors.
The entire engine has factory grey paint on it. I've read here that the injectors and ip should be replaced sometime around 100k miles. Could the injectors be the cause of such poor economy? I'm thinking that if they're worn out, they would be popping too early causing overfueling?
I can't afford to do the ip at this time, should I just wait until I can afford to do both? I'm worried that if the pump is marginal that putting new injectors will cause it to fail sooner. Thanks for any help / opinions.
BTW, I saw these injectors on Ebay, would those be all right?
http://cgi.ebay.com/ebaymotors/6-9-...ies?hash=item2ea80f2e8a&_trksid=p4506.c0.m245
