Mysterious squeak...
bleedblueoval
Blackfoot, Idaho
I bought my first IDI about 2 weeks ago. It has a squeak that is rpm related, i.e. it gets more squeaky as rpm increases. I took off the serpentine belt and checked all of the bearings on the pulleys. The idler pulley bearing was bad so I replaced it but the squeak is still there. The only other thing that I can think of is the clutch release bearing. Any thoughts?
flareside_thun
Reviving The General Tao
Tavares, Florida
If you're referring t a stationary squeak, I myself have been trying to track one down. I pretty much gave up when I replaced the idler pulley, tensioner and pulley and the alternator. Now, it only happens when there is heavy moisture in the air, so that's fine by me. Like I said before, if it's a moving squeak, check your Ujoints. If it's stationary it could be a couple things, namely alternator or AC clutch.
U-joints would depend on, does it squeek when it is moving, not moving, or all the time? More info please.
Disconnect the belt and run the engine without accessories for a short moment, 1-2 min won't hurt. Does the squeek go away or is it still there? If still there same as before or different sounding now?
If goes away, narrows it down to an accessory or pully...perhaps PS ? Dunno...Just making suggestions here...Vacuum pump?
DesertBen44
Grand Junction, CO
Also could be the belt; i was getting a squeak on my serpentine belt in my 95 5.0 bronco and i thought it was the idler, then the ac pulley, then just for the hell of it i put a different belt on and that fixed it. Upon closer inspection of the old belt, no physical defects were noted.
Food for thought at least.
Bradz
