My engine is finally back from the machine shop
cowman79
Mayslick, ky
Well I picked my engine up from the machine shop today. I had all eight cylinders sleeved and bored to stock. I have new pistons and rings. Installed all new cam bearings, main bearings and rod bearings. I had a valve job done on both heads and had to replace three intake valves. I also have a new carter fuel pump to install. I will be installing the tins the first of the week and hope to have it running by the end of next week. If you guys see any thing I need to check let me know.
Kevin 007
Full-floater
Nelson BC Canada
Looks great thanks for the pics!
Just a thought, but next time I do heads on a 7.3, I will be putting the old style 6.9 valve seals on them to allow for a bit of oil to get by the seals and lube the guides. I feel that the 7.3 seals are too tight, they did this for emissions reasons when the went from 6.9 to 7.3 but we also see more valve guide issues with 7.3's over 6.9's. Or I do anyways.
Just a thought....might be worth considering with all the effort put into that motor which should last you a long time now;Sweet
cowman79
Mayslick, ky
I never knew that about the valve seals. It amazes my all of the little differences in these engines.
cowman79
Mayslick, ky
I have new bb's and I have the pump turned up two flats. I am going to seal the exhaust pipes really well hoping to gain a few more psi of boost. I would love to have an upgraded turbo outlet and a 3" down pipe but the funds are a little low after all this work.
idi traveler
Brashear, Texas
If you don't mind my asking, what did it cost to get it resleeved? I have an engine that I will be resleeving at some time in the future and I don't have a clue what it runs. There is a place in the Dallas area called trinity casting service that comes highly recommended that I will be contacting. By the way, it sure looks nice clean and shiny. And thanks for the pictures.
Fordsandguns
Fords Rule
Eastland Tx
You're going to sleeve your engine? Did the engine you got from me not work out? :eek::confused:
idi traveler
Brashear, Texas
No no, everything is fine. I'm going to sleeve it for a hot spare. For the next few years I'm going to be doing a lot of heave towing and if anything happens I don't want to be shut down for long and know that I'm back up and running with out issue.
cowman79
Mayslick, ky
The sleeve work was $125 per hole but because I had them all sleeved he knocked a $100 dollars of and it cost $900.
idi traveler
Brashear, Texas
That's in the range I'm hoping for. I plan on doing the whole bloke also. Did you open up the water passages in the head and block that have plugs in them?
cowman79
Mayslick, ky
The machine shop removed all of the factory plugs I believe. They all have fresh loctite on them.
hesutton
The Anti-Anderson
Bowling Green, KY
Also just a curious question..... What sleeves did you use? Melling, Darton,....????
Cool build man! I see you're in KY too..... Who did your machine work?
Heath
cowman79
Mayslick, ky
Heath
I am not sure about the sleeves the machine shop ordered them but I only seen signs for melling in his shop. The shop I used was Davis machine shop in Paris.
