aaklingler
What does it take to swap a motor out of a van into a truck with a turbo on it, I don't know which turbo?
How much is a used Luk smf worth?
Doggy Daddy said:Vans are so miserable to work on that I'd probably look for a pickup donor. Failing that I'd try to sawzall the body off the van. If you can't get away with that you will certainly need to remove the turbo to get it out.
$250 seems to be a bit much for just the flywheel. Dial-a-Clutch wants $297 for the LuK SMFW, brand-new.aaklingler said:I think I'll have to pass, i'm looking at buying one, the guy wants $250.
