Sycostang67
Scooty Puff Junior
My sister has a 1991 F-250 4x4, 7.3 ATS 085 with a 5spd with at least 143k miles. About two weeks ago she said it started fine but smoked white a lot, and continued to smoke the whole 10 minute drive to the tire shop. It was pulled in right away and only sat long enough to rotate the tires. When they went to start it up, it was hydrolocked. Her husband came home last week, he went out and it fired right up but was still smoking really bad. He parked it in front of their garage, shut it down and let it sit for 20 minutes at which point it was hydrolocked again. There is no sign of coolant in the oil, but the coolant level was too low to check the first time it locked up. He just had the injectors tested in case one was leaking really bad and they all passed. He just rented a cooling system pressure tester. Does this sound more like a head gasket issue or a cavitation issue? The truck had been running fine and smoke free up until the day it first locked up. My sister said the temp never got hot either. I will repost with the pressure results when I get them.
