More issues...
Ididriver
Panama city beach
Replaced the rear crossover line in the return line system. No change.
Took a water hose to the line and ran water through it. No leaks.
Stuck too rags between the ip and intake manifold. Went for a drive. Came back and picked up the rags with a pick. The rags were SOAKED with diesel.
Wich leads me to believe either somewhere on the injector lines there's one peing fuel or the weephole on the ip is leaking.
Return lines are dry.
I can look under the turbo and see a puddle of diesel sitting around the drain plug. Wich also leads me to believe why it's peing when I park and slowing down to a pretty fast drip. The diesel building up around the plug.
What to do now? I got 6mpg with this leak too... Im used to high teens low 20s
gatorman21218
Ashland VA
Dern ok I guess then you need to take the turbo off to see the hard lines. When you get to where you can see everything, I would clean everything off with brakeclean so its dry and then start it and see if you cant spot any leaks. Possibly a hard line is cracked somewhere?
Ididriver
Panama city beach
I have the hypermax turbo setup. I can see everything.
Literally the only place I see fuel is from under the ip.
The rags I put there were soaked.
Nothing else is leaking. Return lines are dry. Hard lines are fine.
Anyways truck is stuck at school right now. Gotta worry about getting it home.
Ididriver
Panama city beach
wmoguy
Colorado
Can you take a pic as to what part of the IP you think the fuel is coming out of?
Ididriver
Panama city beach
I'd have to pull the ip.
The weep hole is on the bottom correct?
I'll double check the triangle plate on the side. Maybe the gasket failed there.
Ididriver
Panama city beach
purg113
new to me f350
twin lake, mi usa
That sounds like mine. My IP just ****** fuel out the weep hole in it thats why I am getting new IP. hope that helps.
'94IDITurbo7.3
HAMMER DOWN!
Fowlerville Michigan
that is the diesel care pump. i think i am the only one on here that won't tell you to NOT run that pump.
search for uhual truck parts in the ebay store finder.
ntjapkes
