travisjulian
- Joined
- Mar 23, 2014
- Posts
- 173
- Reaction score
- 1
93 ford f350 7.3 crew cab dually.
Every day so far I have at some point in the after driving it. Ill go to start it up and tyere will be air in the lines. I bleed them and its fine. Till it happens again. I check all li e including return lines and lines runing to tank and the rear line in back of engine all good. I did notice bolts were not tight on valve cover. Tighten them still same issue. I have put a ton of money in thos thing and feel I at a loss. New tps new trans filtrr new siliniod pack new mls, return lines new plug ends. Dura lift electronic fuel pump new filter. Oil change etc. Help. Also tps is set at 1.1 and wot is 3.92
Sent from my SAMSUNG-SM-N900A using Tapatalk
