I wanted to go this route for a couple of reasons. First off, swaping axles means finding one that has the right gear ratio, is affordable, and then going through all the effort to install it, and I'm sure that would turn into a full weekend ordeal. Then I'd have to worry about front end alignment, shocks, maybe driveshaft lenght... as you can see, it's quite a bit more involved then spending what should have been 2 hours to swap spindles, and leave the drill and the welder in their stored positions. Second, it was already done, and I had a how-to to work from. Why reinvent the wheel when somebody already went through hell to figure it all out.
Now my delema is I pretty much got to go through with the conversion. One of the things I may or may not have mentioned, is that the existing hub on the passenger side melted last June due to a brake caliper failure. It will cost me $278 from Ford to replace that part. I would then end up back where I started, with the least desireable of all Bronco spindle/hub combinations, and getting parts in the future is just as iffy. The reason I'm being so ******* myself is because I usually don't F' up like this, it's damn hard for me to get to a good junk yard, and it's been since freakin' June that the Bronco has been down, and fuel is creeping up to the $3 mark, and I need to get this thing on the road before I go broke.
