Modify OBS PCM to run SD tunes?
Ferdy Mint
Central Texas
We have a 1996 OBS F250 with a 2000 SD motor and intercooler transplanted into it. Right now a NAW6 PCM controls the motor and the E4OD. We got a Hydra and tunes from RiffRaff and found that it won't allow the 60 or 80hp tunes, because it's an OBS PCM.
We have a spare OBS TDE1 PCM on the shelf. Could I send that to a tuner and have it modified to think it's an SD PCM, but still run the E4OD tranny? I keep hearing good stuff about Jelibuilt and 1023.
sheepman
TDS Refugee
Denton County, Tx
Did you contact riffraff about your issues? I don't remember who programs PCMs anymore, there are differences in the SD & OBS PCMs, things like processor speed and memory to name two. Some one with more knowledge about that kind stuff of corse would know better than I would. Tony Wildman (Total Diesel performance) programs those PHP Hydras too.
greenskeeper
PA
What injectors are you running? I'll assume they are single shots to be working with the OBS PCM?
You're limited by injector size regardless IMO so I would just run the tuning that's available for that PCM.
narmalee
arkansas
really? my 97 Hydra does just fine, or is there a diff between PCM's 96-97?
narmalee
arkansas
96-97 would be the same. But OBS to SD are different. Furd/Navistar revised the PCM entirely for the E99 and later. Not interchangeable.
Was gona say, Jelibuilt did tow + 80 and 150hp tunes on mine, and its a 97... but didnt know if maybe there was a diff
