7.3_IDI_guy
Currently ******'
I now have a 93 7.3 with an E4OD and you have to shift the trans manualy for it to work right. If you put it in OD then it tries to take off in 3rd. But if you put it all the way down in 1st and manually shift up to OD then it does fine. It has a nice smooth shift to it. Could this be a tach sensor? my tach at idle is at zero and i know if the E4OD doesnt have an accurate reading from the tach then it will not shift properly. Now I know this is most likely part of the problem but is it ALL of the problem? Any help is greatly appreciated
. But I need to repair the tach sensor and do a filter and fluid change and that will fix it I think, But one more question... How many quarts of trans fluid and what kind is recommended?
