NO_SPRK
User & Abuser
hello and thank you looking at this..
1989 7.3L stock fuel system. new IP. ran out of fuel? put fuel in, bleed. starts. runs. drives 1 block, dies again.
truck wont start. replaced fuel return line kit. new olives in line to IP from filter and from lift pump to filter. check valve shows fuel pumping out. had air till i replaced the 3/8 inlet olive for filter.
removed line going into pump showing fuel is coming out. removed tank line to run on small tank. can only pull start it and it takes awhile. it will run but not idle. yesterday it idled for 1 minute then died.
im ripping my hair out. turning it over with ether still doesnt help. yes i know its bad.
if i remove a IP line to injector.. maybe 3 drips of fuel come out after cranking for awhile... today when it died again i hit the schrader valve and AIR...
