I talked to the tech dept. today at Mahle about my 1441800WR STD hard anodized top pistons being as much as 52 thousands up out of the block. If I mill 25 thousands off the top of them the top ring will be seeing much more pounding from the compression and the piston bowls will be very differant causing the motor to probably run differantly. I would have to adjust my fuel to counteract this possible problem. Thats not a problem but the increased pounding on the top ring bothers me some. They can supply a low compression piston that has the same hard anodized top (144181). What they do is mill the pin location higher in the piston instead of reducing the dome thickness that around 580 thousands if anybody needed to know. I'l bet some of you are asking why are my pistons so high up out of the block??? So am I. I know when the sleeves were installed the deck was milled because I wanted that done to level out the block to the crank that was already line honed. Then when it lost a freeze plug one sleeve seemed to slip down into the block. I know not a good sign either but I had the deck "cleaned up" so I feel thats where the tall demensions are coming from. Plus when I originally assembled the motor I had pistons from 38 to 46 thousands up out of the block. But it ran well at those demensions. What to do now has me really looking at it hard now. Maybe just start over with my spare block and move forwards. I don't know yet....
