MIDNIGHT RIDER
- Joined
- Sep 29, 2005
- Posts
- 4,639
- Reaction score
- 38
Don't discount the likelyhood that they are supposed to be this way. It's been 26 years since I had factory lug nuts on the Moose Truck, but I'm pretty damn sure they didn't spin easily when that truck was brand new, and I noticed that on the Scarlet Moose that they ARE still that way.
^^^ AGREED ^^^
The lug-nuts on the SRW 3/4- and 1-ton Fords, be they gas or diesel, were hard all the way from day one; it has not a thing to do with over-torqueing or improper procedures; it's just the way they are.
This impossible lug-nut business started at least as early as 1977, maybe a few years earlier.
Prior to that, ALL Ford 5-lug 1/2-, and 8-lug 3/4-, and 1-ton SRWs had a plain old acorn 1/2 x 20 stud/nut that used a 13/16 wrench.
The hard ones came along with the advent of the 9/16 stud and much bigger nuts requiring the 1-1/16 (or thereabouts) socket.
There might be some magical replacement nut that better fits the threads and spins on easily, but the genuine factory nuts went on and came off HARD the very first time they were put together and will always be so, regardless.
Although I have no way to verify the information, way back in the day, I was told by one of the mechanics at the local Ford garage that a service bulletin was issued explaining that this was normal, and that the nuts actually were of a slightly different thread-pitch than the studs, maybe even metric nuts forced onto American studs.
They have been a constant source of headache to tire shops and garages from day one.
On the SRW Fords, the odd-ball left-hand threaded studs seem to pop up with absolutely no rhyme or reason as to year-model or rear-axle manufacturer; some will have only the left-rear being left-handed; others will have the left-hand threads on both the left-front and the left-rear.
You can have two 8-lug SRW Fords made on the same line on the same day and one will have all right-hand studs, the other will have left-handers on one or more hubs.
The flange-washered nuts on the DRW trucks are an entirely different animal and can be spun on and off with ease; likewise the coined DRW nuts of yore.
