Low boost...............
geonc
SPIDER BAIT
NECKVILLE North Carolina
I seem to have an intermittent loss of boost lately.
Usually at 80 mph/2500 turns I hold 8-10psi and can hit 20 PSI on a couple of long overpasses.
When starting out from a dead stop, "driving it like I stole it", it would hit 15 psi.
The last couple months I'm barley hitting 8 psi on those hills and mebee have 4-5 psi at the above speeds.
Fresh fuel filter,Stanadyne every other fill-up, clean FPR screen,
fresh or old oil-makes no diff.
It doesn't{and has never}smoked black, I even removed the Tymar type air filter and ran it ...no change.
Change dthe MAP sensor....no diff.
The kitty is gone, 3.5 dp to 4" pipe straight to a 5"tail.
I was so used to hearing that turbo sing and now I barley get a peep:(
The turbo is free and clean and I hear plenty of whistle out the pipedriving past traffic and buildings so the turbo is working.
'Lil help;)
Max Power
Performance drop?
It's not just a bad boost guage by chance?
geonc
SPIDER BAIT
Originally posted by Max Power
Performance drop?
:cheers: MAX! Nice to see Der Boss amongst us!
Boost guage checked out against regulated air supply from 5 psi to 40 psi.
Definate power drop and because of low boost, slightly higher stack temps.
Oddly, fuel mileage is still right around nermal... 17 mpg.
No CEL {check eng light} and I know it works because I disconnected the MAP sensor and the idjit light lit;)
Eng starts fine runs out ok, just LOW BOOST
Any chance the pedal pot could be misfiring?
BTW, no change when I remove the 10 k resistor.
morepower02
minnesota
I would check for a boost leak. In map line or any where between the turbo and engine. I am not sure on the early powerstrokes on the plumbing without the intercoler.
Whit
lost in Why-homing
Geonc,
I had the same problem a year ago and what it turned out to be was the intercooler boot close to the charger, when towing the boost would go up to 36psi and the boot would slip out from under the clamp, when I looked at the boot it appeared to be fine. I put some high pressure boots on , fought it all the way, checked out boot real close after I got it off and it had a very weak spot in it that I am sure blowed a big bubble till it pulled from under the clamp.................good luck.
Cheers, Kevin
Swany
Consiglieri
California
I'd guess that it's the intercooler boots, you might have slipped one off or it's loose.
Mike
Stroker
Cora
I dont think that Geo has an intercooler if I remember correctly. Any chance that your EBPV is malfunctioning or have you gutted that bad boy already?
geonc
SPIDER BAIT
No intercooler:sorry:
EBPV.........................GONE:D
This problem is intermittent at best........It's really buggin me:Drool
Doesn't really seem to build as quick neither.
Fuel system is clean, prolly should check the pressureLOL
dazedandconfused
Rabbit Hash, KY
Check all your boots coming off the turbo and were your turbo bolts on to intake! We had a 97 at work that worked its way loose from the intake!
Mike
Stroker
Cora
A-ha, pull the chip and drive it. You dont have a CEL do you?
placidoert
