Well, when mine was leaking it just left a trail of coke between the back of the exhaust turbine and the pedistal, thats what tipped me off that there was a problem, the coke had the turbine wheel in a bind and my turbo wouldnt spool.
95_stroker said:Well, when mine was leaking it just left a trail of coke between the back of the exhaust turbine and the pedistal, thats what tipped me off that there was a problem, the coke had the turbine wheel in a bind and my turbo wouldnt spool.
No, unfortunately I had to remove the turbo to find it, I dont recall having a huge oil consumption problem but I didnt drive it many miles and I knew that there was something drastically wrong, mileage and performance were significantly affected due to the turbo not spooling.RenoF250 said:Could you see it throught the downpipe hole or did you have to have the turbo apart? Also, how much oil was yours using at the time? Was mileage affected?
