95_stroker said:
You wouldnt (shouldnt?) be losing oil with a bad head gasket. And even if that were the case, why would you have to sell it due to bad HG's?
So there is nowhere that the oil passages can get into the cylinder through the HG? If I have to dig into the engine it is going to be big $$$$ and I cannot afford that right now. That is why I owuld have to sell it. I can handle less than $2k but more than that and I think I would have to do something with it.
I just went out and ran it with the coolant cap and oil cap off. I can see very light mist from the oil hole but feel no pressure when I cover it. There is nothing with the coolant hole.
The turbo would be my favorite reason because then I could put a BB turbo on it. Also, I would not be so bothered by the turbo wearing out. If there is something seriously wrong with the engine I could fix it but I would no longer trust it. I have babied it too much to have it poop out on me.
On the turbo line, I cleaned the boots when I redid the pedestal seals awhile back and now they are covered in oil again. I have a homemade filter on the CCV so that should be stopping that. Perhaps I will look into that further this evening. If it is clean going into the turbo and oily coming out we may have our culprit.
